Open Minded!
Hey pardner,You may benefit by looking into the Tohatsu 90HP TLDI for that Mac. If your going to bump up in HP don't mess around with 10HP that will net you 1MPH if you're lucky. The 90 HP Tohatsu TLDI weighs only about 310# or so which is less than most of the 70HP 4-strokes of other mnfgs. This new 2 stroke technology runs as quiet as a 4-stroke, gets as good a gas mileage (at some RPM's slightly better at some RPM's slightly worse). It requires less maintenance and cost less than a 4-stroke 70HP. Have you ever seen a race between a 2-stroke and a 4-stroke motorcycle? The 2-stroke wins hands down every time. Well the principle is the same in outboard motors. Look at the RPM/HP curves. If you look at the rainbows (engine performance curves) the 4-stroke flatens out early and the two stroke continues smother through the acceleration. Going with the 90 with that much HP in reserve you have the extra muscle to pull any skier you want or do anything you want (within reason) whenever you want to do it, including cruising with a full ballast tank at only 3500RPM up over the wake going 17-19MPH easy. The thing about gas mileage is the slower the RPM the lower the gas consumption. So while its true the 90HP consumes more gas overall, at the lower RPM it takes for it to go 17-19MPH (about 3500) vs. going the same speed with a 50HP (which would be cranking 5500-6000 RPM's to maintain that same speed) the gas consumption is about the same for both motors pushing the same boat weight at the same constant speed. Rule of thumb is that at half the RPM you will use half the gas. The key is going to be at what speed you can run and have the boat on plane. If you have more HP you can run on plane at lower RPM's (which also dramatically reduces fuel consumption on a TLDI). The lower HP will have to run at higher RPM's but as long as you are not at wide open throttle all the time, the gas savings will be significant. 3500 rpm to 3800 is the optimum cruising range for power and overall gas consumption. Most "normal" 2-stroke TLDI users realize 40 to 50 percent less gas usage over 2-stroke carburetor engines. The TLDI system injects air and fuel directly into the cylinder. The oil is a multi port oil injection at different points of the engine (there is no mixing of oil and gas anymore). The TLDI does this at low pressure which is an advantage Tohatsu has over doing it at the high pressure that all of the other 2-stroke injection mnfgs.I highly recommend the Tohatsu TLDI 90HP. It weighs exactly the same as the Tohatsu TLDI 70HP (it is the same engine block). So why go with the de-tuned lower HP model? Always go with the higher HP in the same engine block no matter what you buy. It is wasted weight and wasted motor performance if you don't.As far as longevity it all comes down to maintenance. Most boaters put very few hours on their engines per year, so unless you are commercial or a very avid fisherman life expectancy is really not an issue on 2-stroke vs. 4-stroke. I hope this helps. Kind Regards,BillyBob (part time cattle rustler full time dual purpose Mac sailor)well it's really JonBill but I have more fun signing these as "BillyBob".
