Max-Prop!!!!!!!
Nathan, if you currently have a fixed Michigan prop, going to the Max-Prop will do two things: Flatten your wallet, and make you smile. Hunter(Eddie Breedon) told me that for my 35.5 a 2 blade would be the correct choice as a 3 blade would make too much turbulence on one side of the rudder in forward causing the boat to "Pull" to one side. He suggested that a 2 blade would work much more satisfactorily. I ended up getting a new boat before a new prop, but my 40.5 came with a 3 blade Max-Prop (excellent luck!). Since the blades flip over as you shift from forward to reverse and from reverse to forward, you get the same pulling power in either direction. Stopping power in reverse is nothing short of awe-inspiring! Put way on, take way off, at will. The blades lie flat to the water flow in neutral if you put the gear selector in reverse after stopping the engine and before the boat has slowed. This reduces drag greatly under sail. You can even adjust the pitch to exactly match hull speed to max RPMs. Bottom Line: Highly Recomended, if your marriage can stand the outflow of cash! Ron S/Y Best Revenge
