Brian Mills
I have a Beneteau 361 which was commissioned 2 months ago. I have a 3 blade Max-prop which was dealer installed and has been working well. Yesterday however, while pulling into the gas dock I had a failure of the prop to flip into reverse. Twice I had to flip into forward and back to reverse at higher RPM to get the prop to bite. I tested the prop after leaving the dock and it again worked flawlessly until I was ready to reverse pulling into my own slip when it again acted up. What is the most common cause of this type of behavior? I swam beneath the boat and could find no debris wrapped on the prop. I will have to have SCUBA gear to truely check the blades for free rotation. Any suggestions!
