Material for drive shaft packing
Mar 22, 2022
78
hunter legend nj
Hi Guy's have a 1987 40 ft Hunter legend Yanmar 4jhe engine aboard her an just had a mechanic replace all the major system on it
at a cost $ 8K exhaust from engine black back including heat exchanger , fuel injectors to tank , cooling, elect, sensors, wire harness, alter an starter an she run Great that was down in white rock marina in Pasadena MD last year
An now she in a slip up at the top of the Delaware river in PA happy in fresh water
but i have noticed that when start her up i get leakage by the prop shaft seal an i am looking to replace the inner packing does any one know what the inner packing material is an where to purchase it
If you haven’t already read this article by @Maine Sail. It discusses the pros and cons of each type of packing material and the overall process.
Jan 4, 2006
7,466
The material I've always used in teflon impregnated flax. I get about 6 - 8 years out of it before thinking about repacking.
BTW I run my packing gland DRY. No dripping at rest, no dripping under way. A carefully packed gland can do this.
Don't try for the dry packing gland just yet. Get familiar with the gland. IMO, one of the major causes of a badly leaking gland is a poor packing job.
Jan 7, 2011
5,884
Oday 322 East Chicago, IN
Packing size is usually determined by the shaft size and the stuffing box mfg.
The GFO teflon impregnated stuff is good. I used it on my boat until I changed to a dripless shaft seal.
Greg
Mar 22, 2022
78
hunter legend nj
Ok Thank Greg I guess a good marine repair shop would know what size packing i would need
she has a 1 1/4 drive shaft
Thank Rick
