Thanks for the responses.. Yea I guess that would be too flimsy and would bend when there was resistance. Sumner, I looked at your website, which is great and did contact Dan about his rudder. I asked him about using two pieces of 3/4 inch ply glued together with polyester wrapped cloth and he thought that would work. I just thought after seeing the PVC to ask about it. Thanks again. JMac
IMHO.
if you use a good epoxy and multiple layers, of mat, it will be ok for a while.
you are counting on the epoxy to remain water tight, and as long as you don't break the seal, you're good. but once the water gets in plywood its over, just like rust , you are only buying time...
the plywood route is, 'good enough' to get you out there, But not the proper repair.
now This makes the wooden rudder, a story topper every time!
--- (sumner link:
This is the base stock and the heart of this whole rudder. It is actually recycled Oak from a shipping pallet,
