masthead sheave replacement
321
catalina 25, 30 montauk / manhattan
difficult to raise main. '82 cat 30 with external wire halyard. "assuming" worn out sheave? due to time might hire to inspect/repair/replace. want to have any necessary parts on hand.
if going this route might as well upgrade to internal halyard? advise/suggestions??
thanks!
Garhauer is a good source for new sheaves. Probably less $$ than Catalina Direct.
To run them internally you'll need mast plates.
Go to all rope halyards. Stay Set I've found is too stretchy. Stay Set X has been reported to be completely useless - bad hand, kinks, etc. Samson line is much better. Unless you race, high test isn't needed, just basic low stretch stuff.
idlerr
Aug 5, 2013
1
Catalina 27 Lake Tahoe
I think I need to replace the main halyard masthead sheave on a 27 ft catalina islander. I can't seem to find a diagram but I would assume there is a through bolt that holds the sheave. Is that correct?
