MAST HEAD TRICOLOR LIGHT
Peter I have a tricolor light on my O'Day 26. It was on the boat when I bought it. I really don't use it that often. It has a white strob that is only to be used in an emergency, an anchor light and the red and green with a white light facing aft. These can be used as normal when sailing at night. It is all controled by an added switch box that controls the light or combination of the lights. It has indicator lights on the panel that are supposed to indicate which lights are on. The switch for it is a push button that takes six pushes to cycle thru all the combination of lights. My only problem is, it is not too reliable and I have to visably check the mast to be sure. The box was made in England, I have taken it apart to try to figure how it works, it is full of resisters. I swear there is only one cable going up the mast to the light. Some day I'll drop the mast and try to rewire the tricolor with switches to control the lights. My boat is in the Dunedin Marina near you.I've seen tricolor lights at West Marine. My feelings are you only need an anchor light at the top of the mast. An easy way to get one is a Davis light run up the mast with a halyard. Again strobes are for emergencies. If any one knows this switch box I'd like to hear from them.
