Wires up the Mast
When I rewired my H34, I had the mast pulled. The wires (lights, VHF Coax) do not go up through the mast, but rather, are behind the sail track.You access that by sliding the track out of the mast extrusion either from the bottom, or the top after removing the sheaves and cap. All of the wires are cable tied together so you can't individually pull them out. If you check the Foto Forum posting for repairing the mast step compression problem, you will see how the coax is routed inside the boat. It makes a 90 degree turn under the support beam on its way to the instrument panel. In a pinch, you might be able to fish the new wire up to the base of the mast by going under the port settee and through the lower support beam. Take off the door jamb to the head to expose the wire passage in the compression post and push it up through the overhead support beam and into the base of the mast. You might be able to grab it under the mast by taking off the sheaves and reaching inside. From there, you can connect it to a fresh piece that you drop straight down the mast. It may rattle around, but at least until you pull the mast, you will be back on the air.Good Luck,Allan"Alchemie" H34SF Bay
