So cryptic!
My intention is to charge at max 3.40-3.45vpc (13.6-13.8)
Maybe float at 13.3?
I figure the battery2battery charger approach gives more control limiting current. Obviously the lithium bank's also behind a good BMS.
I believe the Sterling units are good, but only see them sold new ($$) so I'm looking for something less expensive to get me started with a small bank for experimentation.
Keep in mind my MC-614 regulated alt is just one source of charge, I don't want to pay for that level of fine control with every source, which is why charging the more persnickety and expensive (experimental) lithium bank from off the main lead bank seems a good design approach, lots less demanding ways to get source juice into lead.
Other choices I'm looking at are
1 direct charge the LiFePO4 off the Alt, then echo charge the lead bank off the lithium one
2 wait (maybe years) to save up for an ideal one-vendor system (Victron?) that manages everything explicitly designed for Lithium. An example unit for this B2B function would be their "Buck-Boost DC-DC Converter"
So are you saying the whole B2B idea is NG wrt Lithium, or just that these Mastervolt units don't offer the required level of control, or that you also don't like the whole brand, or. . . ?
More explicit feedback would be great.
