Unstepping Mast for H260
I have a checklist at my website. Most of what I've learned comes from the archives and my own experience.http://webpages.charter.net/gkobernus/H260_Web/default.htmlI've lowered the mast in the water but it works best on the hard. You need lots of bungies and cable ties plus the gin pole and the crutch. The manual explains the whole process pretty well. Some tips: The hardest part for me is disconnecting the roller fuller. I've found that attaching one end of the boom vang to the ladder and one end to the RF works well so you can tension the RF and pull the pin. Wrap the drum of the RF in a towel so when you disconnect it, it won't drag across the deck and scratch it. Once you disconnect the RF, secure it to the lower part of the mast with a couple of bungies BEFORE YOU LOWER THE MAST. This will keep the RF under control when lowering the mast. Once the mast is lowered to the crutch, use plenty of bungies to tie the RF along the mast. I also coil the shrouds up and tie them to the safety line with cable ties.You'll need a tool to get the pin out of the base of the mast. I use a small pry bar from Home Depot. It is about 8" long and has a small hammer on one end and a claw on the other. You use the pry bar to wiggle the mast to take pressure off the pin so it can be released. A screwdriver about the diameter of the pin can be useful to "encourage" the pin to slide out. Have some pliers handy. Make sure you secure the mast to the crutch with bungies and tie the mast to the stern cleats so it won't sway when trailering.One you've done it a couple of times, you become amazed how easy it is. People usually gather around and watch when I'm doing it and comment on how elegant the whole process is. Good Luck.
