Don't Recommend It
I have an '85 Catalina 22 and had a real bad experience trying to lower the mast by myself. Even though I was using the main sheet (4:1) attached to the forestay and the jib winch, I had great difficulty in lowering it slowly and the result was about half way down, it swung out to port and slightly bent the mast step.I have since read a lot of posts on various bulletin boards about the "absolute" system for stepping the mast single-handed and I've come to the conclusion that they all have some serious drawbacks since they all require "hands off" the mast at some point during the procedure.The only way you can truly control the mast is to have someone else lower it, while you hold on an guide it to where it should go. At the price of replacing the mast, I for one do not want to take the chance of dropping it or worse yet, injuring myself in the process.I've found there are usually always an experienced sailor or two around who are more than willing to lend a hand. Leave the "Admiral" home for this task if need be, but always get a second set of hands to help. You'll be glad you did.Ed P. "See Da Moon" S/N 13106
