Different method
I have a different take on this because I don't like the rubber compression fittings through the deck and I don't like exterior electrical plug connections outside ina a salt environment. I use an upside-down "J-trap" (under sink home style plumbing) going into a 2" bronze through-hull set in the deck next to the mast. The wires come out the side of the mast about a foot off the deck, drop down, then loop back up, into the pipe and back down into the interior where the plug connections are made at the top of the compression post. The radio antenna wire comes through here also, and is lead back aft to the radio in one unbroken run so there is no resistance from added connectors. This has worked well for me for several years and I don't loose connections fue to corrosion.
