Mast Wiring..........No Fun!
Bob
I have seen a bunch of questions about Mast Wiring over te last few months, and I can dispell a few rumors now. Its no fun. Fortunately my mast is on the deck, unfortunately all of the old wiring was coiled (not so neatly) at the bottom of the mast and I had to pull with needle nose pliers and cut it out in six inch increments. The bottom of the mast is not coming off, I think someone used 5200 on it and the screws had to be drilled and retapped. The opening in the bottom is about 1 1/2" by 3" (not a lot to work with). I used a plumbers snake to pull two lengths of nylon line to the top. I pulled some 18/4 wire and a RG-8 coax all the way to the bottom, and then fished out the steaming light wire through the half inch hole in the mast. I measured carefully and left a loop at the steming light point before I pulled the cable. I used 6" pieces of pipe insulation every 2 feet to cut down on the mast slap (hopefully). The foam is taped to the cable. I used screw on wire ties at the top and bottom, all the connections are crimped, soldered, and have adhesive heat shrink. New lights and new antenna installed. I had to fabricate a new windex braket to move the vane outboard 3 inches (hopefully it will be easier to see as well). Not a fun job at all, and when you put the mast head back on, make sure the cable isnt in the bolt hole when you push it through or you can start all over again. Trust me, I know. I already installed new waterproof connectors on the deck, one for the coax and one for the lights. New waterproof connectors on the cable ends where they exit the mast about 4" above the cabin roof. Now I just hope it all works. By the way, there is no wire chase or conduit inside the mast, its wide open, except for the bees nests, frayed rope, old wire, and 29 years of dirt. Enjoy.........
Jun 4, 2004
63
Hunter 33_77-83 SubBaseNLon Groton, CT
I feel your pain
Last summer my antenna cable shorted, I tracked it to the connector inside the base of the mast. I spent several hours at anchor, peeping through a screw hole on the front of the mast while fishing with a piece of wire trying to get the cable and connector to come out through the sheave opening. I was able to rig a temporary fix. While the mast has been down over the winter I completely re-wired it, so no more problems when the mast goes up (I pray) Sounds like you spent many more hours doing the same kind of thing. Just remember, when doing work like this: "That which does not kill me, only makes me stronger" (or drink more).
swabie
HMMM
*GRR And do not forget who was hanging off the ladder pullin' the string and for that matter every thing else I have have done stuffed in the anchor locker tighten all the toe rail bolts scrub off the lettering, sand, tighten knuckles never be the same ... gesh behind every man their is a (pouting)... Hmmm nooo recognition the little woman oops sorry for my little out blurb I'll sit in my place now bess
Royce
Bottom piece
needs to come off. You have corrosion at the base of the mast and the base plate and the two have grown together. I had to drill out all my screws and with some penatrating oil and persuasion, it came off. I've read of people who had to cut off an inch or two of the mast to get to good metal. I ran a conduit up the inside of the mast. Good luck, Royce
Bob
Mast Corrosion
Royce, I don't see any corrosion inside or outside the mast, I just see glue or tape between the mast and mast base. I already have the wiring all done, and the holes tapped for new screws, but thanks for the heads up.
