Scott
I have to admit that electrical wiring is not my strong suit (by far) and since I am installing new lights, a new wind instrument and new coax for the VHF antenna on the mast for my winter re-fit project, I bought Dan Casey's Sailboat Electrics Simplified for guidance. A few things leave me with unanswered questions.I am planning on using a four-way plug connection to join the wiring at the mast base. I will have an anchor light drawing .83 amps (10 W) with a total round trip length from the terminal box to the top of the mast of 100', a steamer light, also .83 amps but the length is 65', and the deck light drawing 1.67 amps (20 W)with a length of 65'. Using the wire size formula for 3% voltage drop I find that the steamer and the anchor lights can be 16 guage and the deck light can be 14 guage.I assume that even though there is a break in the wiring where the deck plug is located (my mast is 33') I have calculated the round trip length as if the wire runs were continuous and independant. I thought about using primary wire to run positives up the mast to the lights and primary wire to daisy chain the negatives for the 3 lights down the mast. I reconsidered and figured I would rather use duplex safety wire because of the added insulation to the wire. I assume that for the 4-way plug to work, I would pigtail the 3 negatives into the plug and run one negative primary wire from the mast base to the terminal box. So to summarize the wiring, I will have 3 primary positive wires from the terminal box to the plug at the base of the mast, 3 duplex wires inside the mast serving the 3 lights, and one negative primary wire from the plug back to the box (about 15' one-way).So now, sizing the primary ground is my first question. If I assume the run is only 15', for 3.33 total amps it appears that a 16 guage wire is sufficient. That doesn't seem logical to me so I assumed that the formula should be used assuming the combined amps for the longest run of 100'. This leads me to a 10 guage wire. Is my logic faulty? I am assuming that ALL lights can be on at the same time (by mistake) even though it isn't logical for the anchor and the steamer to be on at the same time.Also, I thought I read that it is not a good idea to have a coax cable and an instrument cable in close proximity. I planned on putting them both inside the 1-1/4" pvc conduit that will be used to run all the wiring. Is this something that should be avoided? I figure that if the wind instument is disrupted during a vhf transmission it would be no big deal. Any comments about this?
