Hello all!
I am looking for the box that I see on the 1990, 91, ... Larger Hunters. It is the mast wire pass thru unit on the deck. I want to find some one that sells them. Our 42 Passage has the wires run down the inside of the mast then thru small pipes to the inside.
I want to change this so the mast can be removed easyer and not have the ends cut off each time.
I found one in Europe that I will show in the photo. But I would like to find one here in the states if possible!
Thank you in advance for your help!
Dean
Dean
