mast winch for reefing
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
I have been advised that I need a winch mounted to tension the reefing lines through the boom to reef properly. There is a pedestal below the boom on the mast for mounting. What do others use or have ?
Mar 6, 2008
1,374
I would not advise use of a winch as it may tear the sail. Pull by hand only.
DougMc
Hunter 36 Erieau Ontario
Clew must be pulled in tight to flatten and depower main. Very hard to do without a winch, I would use a cabin top one with clutch so the same winch can be used for second and third reef.
Oct 7, 2012
15
Hunter 28.5 and 40 windsor Ontario
We have one on our 40 and the wife lowers the main as I am reefing work's great. On the 28.5 it is a pain in the butt to reef unless you are HEMAN :theman:
Dec 14, 2003
1,442
I set my 2 reef lines running to the cockpit so I use the cabin top winches when necessary.
