I have had my 29.5 hunter only a few years. The club I belong to requires that all masts be un-stepped for winter storage. With the 29.5 being the typical B&R rig with no back stay, all the mast adjustments are done with two side shrouds and the head stay. Stepping the mast in spring and then going through the various adjustments to finally get the mast bent just right sometimes takes several weeks. If I follow the instructions that came with the owners manual the shrouds are way too tight and the mast has too much bend in it. So I have come up with my own system using a wire tension gauge. It's not perfect, but it works. Having a mast that requires a certain amount of bent in it is always a balancing act. Too much or to little bent will mis-shape the main sail.
Is there any 29.5 owner (or other Hunter model that does not have a back stay) out there with with more experience setting up this type of mast system and have developed what they feel is good system that can be set up quickly.
