MikeY
Sorry it took so long to respond...just re-read article...I had slack at leeward side in 5 knots, so I hooked on my auto-pilot-bungee, and tightened the lee side up at 5 knots. Will check at 10 & 15 too.Also, I've tried running the lines from the jib/genny INSIDE the shrouds. Makes for a flatter and tighter sail on bottom too...inside spreaders doesn't work well in some winds though as sail will touch lines...also are spreaders supposed to point backwards ?Rack & bend - is rack with mast straight and bend with mast curved, distance from main at cabin ?
