Going to have two lanyards installed at the top of my mast (see image). The bare cable is backstay and white wirerope is topping lift.
How would you recommend the two lanyards be attached? Drill new holes and mount parts or use existing hardware already up there and just hang hardware off of them?
These will be non-load bearing lanyards and will only be used to raise a dipole for 20 meters, and also an alternate backstay antenna. These antennas are in the future even though the 20 meter dipole is tuned and has been used on the boat before.
Open to suggestions before I have to work done at the boat yard.
Thanks
Thanks
