mast support bulkhead
Apr 25, 2008
64
hey everyone, i'm continuing the refit/restoration of number 1076, and had a quick question for anyone who has replaced the bulkheads under the mast. My Vega shows no sign of a mast compression problem, but a leaky portlight the previous owner never fixed allowed water to wick up the bulkhead and put a funny warp/wrinkle in the port bulkhead. My question is if port and starboard bulkheads are the same shape, just a mirrored image? Can i pull both out and make a pattern from the starboard side or is the port slightly different? If it is different does a pattern exist to fabricate a new one, or if the pattern does exist i can avoid disassembling the starboard side which is intact. Any help would be much appreciated. Thanks in advance.
Fair winds,
karl
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi Karl
I know that it is not an answer to the question that you asked - but:
I have just re-inforced the mast support beam *after* it became necessary
and as you are replacing the port bulkhead anyway
and as you are doing a general refit
and as your boat is even older than mine :)
I would suggest reinforcing the support beam....(When I bought my boat in 2005 I noticed that the door to the forecabin
rubbed against the shelf on the port side when I tried to close it.
I managed to "persuade" it to close and forgot about the problem till a
month ago when I found I could no longer shut the door as it was rubbing
against the mast support beam.)
Just my 0.02 Euro worth.
Good luck with the bulkhead replacement.
John
V 1447 Breakaway
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
Oct 19, 2019
921
Forgot to say that I bought reinforcement kit from Steve Birch from whom I
also received lots of very helpful advice...
John
V1447 Breakaway
