mast stepping/un-stepping on hunter25
Jul 7, 2009
2
2 25 guntersville,al
I've taken my mast down twice over the years but it's been a long time ago and I always had 'supervisory' help....can someone give me step by step instructions for taking my mast down on an '82 hunter 25....
thanks
Nov 9, 2009
69
catalina 25 wing keel rutledge tn.
thanks
I have a catalina 25 and Lowering the mast should be similar to your boat. I made an a frame using rails for the top of a chain link fence. I bought the railing at Lowe`s. I bent the ends slightly so that when I put them together they form an a. I attach the the frame ends to the stanchions with clamps that I bought along with the railing. Where the two ends meet at the top I have a bolt holding the pieces together. Next to the bolt I have a shackle mounted. Start with the a frame laying down on the bow pulpit, attach the jib halyard to the a frame. attach a line opposite from the jib halyard to the forstay with a block to use for lowering . I also built a crutch from a 2 inch square tubing with a roller on the end that I place into the pintles in place of the rudder to lower the mast into. When everyone is ready disconnect the forstay and the forward shrouds and she is ready to be lowered.
-na -NA Anywhere USA
if you want me to call, send your name and phone number and I will call. Been to Guntersville years ago delivering a Catalina 25 wing keel as a former dealer but now retired. I was also a Hunter dealer as well. YOu do not have a mast raise system so I can talk you thru what needs to be done.
dave condon aka crazy dave
Nov 8, 2010
11,386
Just don't let this guy take charge.
Jul 7, 2009
2
thanks dave....good advice
