I think Steve is correct. The plate is screwed on from on top. The screws are threaded into an aluminum plate embedded in the fiberglass in that raised section around the step. Now would be a perfect time to put in a better slightly longer wire conduit tube and seal everything very carefully so there can be no leakage to cause the support beam to soften.. good luck!
