I have a 1987 Oday 272LE. I'm hopeing that someone can help come up with a new way to raise the mast! Right now it takes 4 grown men to lift it into the upright position. Between the small hinge pin and the traveler for the main sheet in the way, it is quite a job getting the base of the mast into the step. Then the mast must be held in place while people are getting in position to raise the mast. Doing all of this while the boat is on the trailer before launch is quite a task! Has anyone redesigned the mast step and changed the hinge point to help with raising the mast? Any other helpful hints, ideas or coments on how to do this would be great. Thanks Doug
