Mast step
Oct 30, 2019
119
How to keep water from entering the boat via the mast step hole?Nicholas Walsh
Nicholas H. Walsh P.A.
111 Commercial Street
Portland Maine 04101
Tel. 207/772-2191
fax 207/774-3940
This email was sent from the law firm of Nicholas H. Walsh P.A. It may contain information that is privileged and confidential. If you suspect that you were not intended to receive this email, please delete it and notify us as soon as possible. Thank you.[Non-text portions of this message have been removed]
May 30, 2006
1,075
I think there is more info on this if you search the archives,
But, I used the plastic pop bottle technique.
Cut the pop bottle in half. Use the upper half. Wires come down the mast, into the small pop-bottle opening, and then continue on to the inside of the cabin.
The pop bottle is like a litte roof that sheds the water to the outside of the mast step pipe.
I got some of that grey electricians putty that can be purchased at home depot, and crammed it up the inside to the top of the pop bottle. Then I poured 5200 from the top side of the pop bottle to seal.
rb
Nicholas Walsh
Tel. 207/772-2191
fax 207/774-3940
