Mast Step Issues
John
I will post the basics and better pictures as a photo forum article IF I ever finish, but for now I thought I'd post my progress to date. Hopefully this will be good reading for some of you, if not it will be long and unbearable. I noticed a slight depression a few mm's down and about an 1/8 of an inch width all the way around the oval aluminum mast base, and had some slight cracking around the cabin top step. I thought I would just be replacing the step core, as the PO had told me it had already been repaired, and I suspected if there was a new issue it would not be widespread. In opening up the top of the step, I found this... the previous repair had been to cut through the step, and the cabin roof, and replace the core with 2 layers of 1/2" hardwood ( I believe oak ) in a trapezoid shape. No glass or epoxy between the two layers. The 2 pieces of wood were wrapped in fiberglass cloth, but it had only been wetted out on the top and bottom, not the sides. The sides of the remaining roof core ( balsa ) were scraped back a bit, but were not sealed and filled with epoxy, but spray in expandable foam.... For reference, there are some pictures at: http://www.geocities.com/attiraj/H30maststep.htm So the step started leaking again ( I'm guessing before I bought the boat ) water migrated into the rest of the plywood layer of the step AND through the cabin roof layer of balsa. I ended up cutting out a large portion of the deck after lots of tapping. The piece cut out includes the elevated mast step. The rotten and water soaked balsa was everywhere. One important thing to note on this. The " T " shaped mast step is hollow on both sides. Meaning there is a space between the top of the roof deck balsa and the glass bottom under the plywood of the step. This is VERY bad as it allows leaking water to spread across the top of the balsa in a large area. If just sandwiched balsa core, my understanding is it take a long time for water to spread through and soak then rot balsa. In this case, it had spread far and penetrated. The basla was totally soaked. I have since cut out tons of balsa and replaced, and have built up a 15" by 12" pad of solid glass under where the mast sits. I'm just under the thickness of the cabin roof balsa right now. My dilemma is trying to decide on the next step. My choice is: 1) do I replace the skin cut off, and rebuild the core of the mast step with all glass or maybe an aluminum plate? 2) OR do I use new cloth to layer the whole deck roof, and build up a new mast step that is more of a square pad of solid glass to get the height right ( like the Cherubini H33 ). The usual prescribed method would be # 1, but I have found that many areas of the removed deck piece had not been originally wetted out, and in some areas that unwetted mat looks " rotten ". In addition, the surface of the core is quite uneven ( from the unevenness of the inner skin ) and so I am concerned about getting good surface adhesion when replacing the deck piece. I would drill some holes for air pockets to escape, then use lots of sand bags to try to evenly weight the deck piece back on. Could lead to a bumpy surface though. I think vacuum bagging is above my comfort level, and would be even more difficult given the large area to seal. The benefits I see to # 2 would be to ensure an air pocket-free solid deck sandwich. Great adhesion, and likely a better finished surface. Also eliminates the possible issue of the strength of the areas of the deck piece that were not originally wetted out ( although I would obviously wet them now before replacing in # 1 ). The drawback to # 2 is replacing the " T " shaped deck step with a more H33 like smaller square step. Rebuilding the " T " over a new deck surface would be more trouble than just living with option # 1. My concern is that the " T " shape is structural, and therefore I need it. I'm leaning to thinking it is not structural though. It was cored with plywood, and was hollow to the deck core on the sides. Maybe in that configuration it is necessary, but in the case of a solid glass cabin roof and solid glass pad, I think that may negate the need for the " T ". I actually have the question in to Hunter Tech, but given their situation they definitely have other, more pressing issues at hand. I'm also not sure they will want to offer advice given the age of the boat and the nature of the question. Even though I think #2 would be easier, I'm leaning towards the "safer" route of # 1, but this changes hourly.... Any naval architects out there?
Jun 2, 2004
425
- - Sandusky Harbor Marina, Lake Erie
Aluminum Plate
I'm not sure of about the problems you associate with the aluminum plate. Ours basically replaced the balsa layer in the deck under the mast, along with epoxy that surrounds it, and was soaked into the good balsa around the repair. (We had good balsa within 3-4 inches of the step structure, so we didn't have your area to fill. Then we rebuilts the deck level over the aluminum. Finally, the "T" shaped section was built on top of the deck layer. We use well sealed marine plywood, but you could bend another aluminum plate here, too, The advantages of aluminum are: - distribution of the mast force over a broader area. - water/rot-proof. - cheaper than resin. - didn't have to wait for a thick resin structure to set. David Lady Lillie
John
thanks
I appreciate the reply David. I have read your posts on this in the archives, and they have been very helpful. I don't really have any issue with using the aluminum plate. If I replace the deck piece with "T" in it, I will likely use and aluminum plate, or possibly well sealed hardwood. I've already done the deck core layer ( your aluminum plate ) in glass, and as you said, it is a pain to lay up so many layers. One thing I'm not sure on for your repair was did you you actually cut the " T " part of the deck top completely off? or is the above mentioned part of your repair all done through cutting off just the top layer of the " T " and rebuilding both layers through that access from the top? Thanks
Jun 2, 2004
425
Removed the "T", then the deck
The T was a fiberglass shell over rotted wood, on top of the deck layer of fiberglass. It was completely removed. After sounding the deck below and around the "T" we cut a hole about 10" by 20" in the top fiberglass layer, exposing the rotted balsa layer. Then we pulled out the balsa, working back under the deck until we came to clean wood. This was anywhere from 2" to 4". Then we rebuilt the step from the bottom fiberglass layer up by: - Pooling liquid epoxy to give a flat surface, and seal the wood. - placed a 1/2" aluminum plate on the hardened, flat epoxy, and flowed epoxy over it to fill any voids around the edges. - rebuilt the deck fiberglass layer on the aluminum plate, tapering it into the existing fiberglass, and building up the rounded shape in the middle. - rebuilt the "T" with plywood and fiberglass. - drilled a new hole for the electrical cable, filling it with epoxy, then drilling a gain and inserting a polyurethane pipe to carry the cables. Then we painted the whole cabin roof with sand non-skid, so there is no remnant of the repair job. David Lady Lillie
