Mast step installition abi alluminum folding
2
- - Shark River N.J.
These have 4 holes for installition. My question is do use ss sheet metal screws,ss cutter (self tapping machine screws) or alluminum rivets. I have a 77 Hunter 30 and she has a 39 ft alluminum mast. How thick is the mast, would machine screws have space to catch hold? How about chaffing on haliards inside the mast? Jerry
Ross
Jun 15, 2004
14,693
The aluminum is about 1/8 inch thick give or take
a little. You want to build a ladder almost fory feet high with the steps fastened with screws driven into that. I wouldn't climb it. You can get rivet-nuts that will put a full screw diameter length of threads into each hole. These also offer a known pull-out stength. You can get an installation kit and as many rivet-nuts as you need for less that 100 dollars from McMaster-Carr.
W
Waffle
Mast Steps
I would guess and it is a guess that you would use tapping machine screws. They would be small enough and do not have a point so you don't chaff the halyards. I had a friend who install the angle mast steps all the way up his mast. I think he used alluminum rivets. I would as the riggers at your yard. I don't see the need to install them and I think you are safer in a bonsum chair. I could see the need for a folding step or two to reach up above the boom to cover the sail. Wif
F
Fred
Stainless rivets are available. In a thin
material like a mast, the rivets are stronger than a screw, because they are a through fastening with the bulge of the rivet inside the mast. Screw rivets may be even stronger.
