MAST SLIDES AND SLUGS
Oct 25, 2008
168
Albin Marin Vega Bogue Chitto, Miss
I was looking for some sail slides for the my #2930 Vega when I saw
some sail Slugs, and it occured to me. Is it possible to replace the
hanks on my old sails with slugs that would fit inside my roller
furling track? Has anyone ever experimented with this?
Oct 30, 2019
234
When I had a Plastimo Roller Reefing for my Genoa the reefing kit came with slugs to slide up the track to use a hanked headsail if required. I can't see them in the Plastimo Catalogue but it might be worth contacting them to see if they will supply them as spares The diameter of the slide fitted the Plastimo track but I do not know the diameter but needs checking to see if it is the same as the headsail track on your boat.
David Wisdish
Ponteneur V3283From: mageekenneth
Sent: Monday, November 10, 2008 2:46 PM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] MAST SLIDES AND SLUGSI was looking for some sail slides for the my #2930 Vega when I saw
Oct 19, 2019
921
Albin Vega 27 Limerick
I did this to convert a hanking headsail into a furling one.
Worked well.
John
V1447 Breakaway
David Wisdish wrote:
Oct 30, 2019
234
Hi All
The Part Number for the PVC Slugs that fit into the Plastimo Jib Reefing Track to permit the hanking of a Jib sail rather than the use of a bolt rope is as follows:-
Hi David,
Part number 17065 is the correct part. If you require any other assistants please contact me.
Many Thanks
Carl Gilbert-Wood
Sales Administrator
Navimo UK Limited
David Wisdish
Ponteneur V3283
Sent: Monday, November 10, 2008 4:54 PM
Subject: [AlbinVega] Re: MAST SLIDES AND SLUGSThere is another company that makes these: Kiwi Slides.
I like the ability to drop a sail on a furler without having it come
off the foil. I haven't played with these yet, so I don't know how
good they are.
Peter
#1331 'Sin Tacha'
May 30, 2006
1,075
Hi Peter,
The reefrite system is one I am considering. Anybody have any experience with this system?
Also saw US Spars at the Sailboat Show and they told me they could ship me the whole foil in one piece. This seems to be a benifit to me, but I'm not sure how much.
I posted on another website about roller furler failure modes, and most people mentioned problems with the line getting caught in the drum.
I'm still not sure what to do..
rb
