Scott
I'm working on the mast for our Starwind 27 this winter and intend to replace the lights. We have the typical all-around anchor light up top and the masthead steamer midway up the mast. The electrical connection was a pair of 2-wire strands that connected into a 4-pin plug at the base of the mast. We have switches at the electrical terminal box at the nav station for anchor and steamer and we have the old style box with fuses. I am thinking of putting a masthead/floodlight combination in. I don't want a floodlight on the spreader and I thought this would be a good alternative. Does anybody have any feelings about this?I assume that the combination light will have a 3-way wiring connection (2 positives and a common ground?). Obviously, I do not want to have the floodlight on every time I switch on the steamer and will need a new separate switch for the floodlight. I assume that this will not work with the 4-pin connection (used for both anchor and steamer) that is currently popping out from the coach roof. I suppose I will have to bring new wires back to the box at the nav station. Where do I mount a switch for the floodlight? Can an exterior switch be mounted on the mast? Not a good idea? Should I just pick a convenient location near the companionway? I don't have an available switch at the box so I can't put it there I assume.I am pretty weak when it comes to electrical (as it is probably pretty obvious) and will have to do some research to size the wires correctly but I would appreciate a few helpful suggestions.
