Mast replacement cost
_evan
Mar 25, 2021
2
islander 32 Morro bay
Hello all, I am currently in the process of searching for my first sailboat and have come across my first potential boat.
She is a 1965 islander 32 however she is in need of a lot of repair. All of it seems repairable however the one major issue that stood out is the current owner said about a year or so ago he begun to see that the mast had become de laminated about halfway down and he did a repair on it. The mast looks good however speaking with a friend who is slightly more knowledgeable then me on the subject he said that you simply cannot patch a mainmast in that way. from what I was told is it has to be completely stripped down and re laminated. I was also told by the owner that this boat shouldn't be considered something that I can take out on the weekends sailing as its only use has been as a live aboard for at least the last 10 years.
While I understand that this will be a massive undertaking to put this boat back to sea, that is definitely a goal of mine. I am primary purchasing the craft for live aboard status and the fact that moorings and slips are rare in my town but I would like to take her out occasionally on day sails and even a possible long trip to Catalina island.
I am unable to fork over large amounts of cash if repairs like replacing the main mast come up. I do have time to continue looking for a better starter project however I would like to get a recommendation from the sailing community on the real scope of work that this boat could be should I try to get it back to seaworthy status. I know this is hard not looking at the craft yourself but I was hoping for an extremely rough ballpark. she has been at the mooring ball at least 5-10 years and all of her sails have also been removed as they were completely weathered over the years so I assume that nothing will be usable topside and all sails and rigging will have to be replaced. The atomic 4 does run however she is currently running off an external fuel tank which I was told is normal with age. The fuel tank is rusted out and I do plan on replacing this. She also appears to have never been modernized with new equipment since new so I will also plan on at least a few safety and GPS modifications as well as totally rewiring the boat and overhauling the engine. I do have another atomic 4 I can use for parts that I know runs so that is a big plus for me with this boat.
If the main mast is needing the scope of work that I was told I will probably consider other options however I was hoping that someone might tune in as to weather a repair like that is alright for a boat. The nearest port that could remove the mast is a days sail away and I have no idea how much a mast overhaul or how much a new aluminum mast would be. I would like to keep the boat at the mooring ball she is currently at as I do not have the funds to pull her out or pay someone to service her.
I understand this is an ambitious project however I consider myself to be a dedicated person.
Lastly, I would consider other boats if someone knew of a mooring or slip in the Morro bay area that was for sale or rent and had live aboard potential in Morro bay/ Avila beach.
Thanks all
Evan
dLj
Mar 23, 2017
4,768
Hard to really say anything without photos and a lot more detailed information, but from what you've said so far, I would move on and find another boat.
dj
Likes: Leeward Rail
Is this a wooden mast?
While this may look like a cheap place to live, it is not a boat to get involved with. Walk on.
Jan 23, 2021
114
beneteau 323 Corpus Christi marina
You don’t know what you don’t know.
Experienced sailors (not including me, but including some others on this forum) have some idea of what they don’t know, and they know enough to walk away.
_evan
Mar 25, 2021
2
thanks all for the replies. I sadly figured that this was the outcome of all the years of neglect the boat has experienced. I will continue my search for a more reliable home.
