rig tension
my elbow slipped off the arm chair reading some of these responses. i suppose the worst can happen to someone. there are allot of those h34 around all over north america. maybe 1100 or so. i have a harken furler that looks pretty sturdy. are they safer than the hyde system? my foil looks like a 2 peice job, and is not perfectly straight after all these years resting on top of the boat during the hard winters. i have a real good rigger that sets mine up every year, and i just do minor tuning to keep it safe. ive seen him do everything from j145 to dingys, so i can trust his work. he sets my rig up just firm, and never warned me about any dangers. if you can play your shrouds like a high guitar string, there way too tight! ive seen rod rigging that tight on j boats, but thats an entirely different animal. for a coastal cruiser that was designed to handle lighter demands, and stresses from a crew, should have the rig tensioned for alittle give, to protect all the hardware on board. chain plate, and deck presures will rise too high, and may deform the hull with a rig thats too tight. and by the way some h34 have compression post problems, another reason to keep rig presures down to normal. mine looks ok after all these years so why push my luck. forestay sag is acceptable with a firm backstay setting in winds 12 knots or less. i downsized to a 125 last summer for the same reason, to reduce sag up front, and reduce high sheet loads on those little winches, and my arms that are just getting over tennis elbows. have you guys ever had that from flying a 150? dropping from 745 sq ft to 650 should give all the rig attachment points a rest after all these years, including all your own joints too.
