Pointing
Kevin,Raking the mast forward reduces weather helm and may even induce lee helm, which in turn can make your boat unpredictable as it heels. Before I messed with forward rake I would want to make sure the headstay tension is sufficient to create an efficient foil.When you are pointing, how much does the headstay sag? Ideally, for upwind work, you want no sag at all. This is not practical, so you come as close as you can.Justin - O'day Owner's Web
