Single Hand Mast Stepping
I made an adjustable mast crutch with two different sizes of tubing. It has a boat roller on top, so I can roll my mast back to pin it at the tabernacle. I can pin the crutch in three positions: transport (low), sliding the mast back (medium), and raising (high). After attaching the mast at the tabernacle, I tie my painter in a U shape bridle on the pulpit, then attach my jib halyard to the center of the U. I then raise the crutch and pin it at the highest point...be sure your back stay is not tangled and laid-out in the cockpit. I can then stand on top of the cabin and lift the mast from waist height. After the mast is up, I pull and cleat the jib halyard. This will hold the mast up while pinning the forestay. I like to have the wind coming directly over the stern, so I do not have to fight it while coming up with the mast. It is not a good to attempt raising the mast with a strong cross wind. David
