to RJ from Valentina
Sorry, have not posted the rest of the pix on my mast raising system...the ones I took, came out blurry, so, will re-take it as soon as I can."Abby" is right- it's really simple. The higher the gin-pole is the easier it is to pull the b/tackle. Ideally, a gin pole should be 3-4 inches shorter than the distance between it’s attachment to the deck and the bow chain plate(where the forestay gets attached) those 3-4 inches will provide enough space for your hands to attach the forestay. On my boat this length is about 7 feet. Menards sells that aluminum pole for $16 and it’s 6 feet -good enough form me. Some people use their trailer winch (instead of block/tackle) to put the mast up....(kinda kool)..all you need is a long enough winch cable to reach to the top of your gin-pole...and you are all set.Regarding the hinged mast step...well… ideally, you want that hinge, but technically, the bolt and the original mast step act as a hinge just fine.A good thing about not having that hinge in the mast heel is that you can use the mast for stowing all the wiring while transporting, plus I stick a t3 ft tube in there that gets bungee corded to a furler that is slightly longer than a mast. This way, the furler stays straight and does not get bent while trailering /storing....but that's another story...The rest of the pix will be posted soon, I promise!V.
