Richard
I just bought a '95 Hunter 26, and put up the mast. The previous owner had very helpfully shown me how to take it down and put it on the trailer, and I walked through the book to see how to reverse the process. My question is how much space should there be between the bottom of the forward part of the mast and the step? As I was raising it, I had it nearly all the way up, and could nearly attach the roller furling, and gave the main sheet tackle (attached to the anchor locker eye, per the instructions) one last tug, and there was a 'bang' and the mast then seemed to settle into place and we could finally attach the roller furling. I went back to the mast to check and see if all was fine, and found three broken plastic mainsail slugs within the track at the bottom rear of the mast; the bottom-most one was slightly wedged into the bottom of the back of the mast, and I found a bit of white plastic on the top of the cabin (I called the former owner, who advised that the inside part of several slugs had broken off this spring inside the mast, so he wasn't surprised that they'd worked their way to the bottom while being jangled around for 200 miles on the highway and then raised). The bottom of the front of the mast, however, seemed flush with the step.Concerned that I'd broken something, I took the mast down about half-way, and found that there was nothing stuck under the base of the mast -- and the broken slug pieces came free and I could push them up the slot in the base of the mast a bit. I then reversed the process and pulled the mast the rest of the way up, and attached the roller furling. The concern I now have is that the bottom of the front of the mast is about the width of two quarters from being flush with the top of the step -- when I pulled it all the way up this time, there was no corresponding 'boom,' and it was easy to attach the roller furling. Somewhat concerned that it wasn't flush, I took it half-way down again, found nothing impeding its progress at the bottom, and brought it all the way up again. Still not quite flush. The boat was then put on a gantry and launched at my marina. I figured the mast might settle in to the base, flush, somewhere in that process, but it didn't.My question after this all-too-long essay is does it make any difference, and if so how much? The shrouds are taut and the roller furling is attached just fine, so I should be safe, right? Taking the mast down yet again when it isn't clear it'll make any difference seems like a pain if the benefit isn't clear, but I don't have the experience that all you have, so I look forward to your advice. Crazy Dave, are you out there?Thanks!Richard, in a yet-to-be-named Hunter 26 that I'm looking forward to sailing!
