Ugh on the intial
That is always a problem during the intial set up with the struts. Here it goes.With the mast down and resting on the crutch, make sure it is in midships with the boat. Measure the hole on each side of the mast to the outer edge of the boat or to the strut base. Make sure the hole is straight thru the mast and if not, compensate for that. Now place the struts on with the tops adjusted. Rasise the mast. Make sure the struts do not bend. If they are bent, remove with mast up and readjust and then lower. If you find that the mast is hard to unpin, make sure it is amidships and the mast is not tilted sideways. I have found that filing the mast base pin holes do help. also, you may have to do one more slight adjustment with the mast struts. Then it usually works right. IF you are trying to unpin and find it difficult to remove the pin, I always ask some one to do the wiggle wiggle. That is to take the spreaders and wiggle them which makes unpinning easier. I hope that helps.I do the wiggle wiggle all the time when my exterior goes walking. Ha!Also, help out with Jason on his inquiry regarding Hunter and MacGregor. ThanksCrazy Dave Condon
