Mast Raising Jig Hunter 23 (and maybe others)
Apr 15, 2025
3
Hunter 23 Mississauga, On, Canada
Hey all, I was browsing your site and came across a few posts of people having issues raising their masts. I figured I would make an account and post a mast raising system I developed for my 1987 Hunter 23. The link below is to my YouTube channel of a video of my mast raising jig I made. I have since updated this setup to replace the wooden jin pole but, in general, works the same. This system allows me to easily raise the mast solo with full sway control. I haven't tried this on the water yet but it looks as if it shouldn't be a problem there either.
I hope it's ok to post links.
Thanks.
Likes: Timm R Oday25
Mar 2, 2019
621
Oday 25 Milwaukee
We have a very similar setup . We run the line from the blocks back to the winch on the mast . We now have the advantage of using a winch handle
and being able to cleat off to check stays and wires are not snagging
pgandw
Oct 14, 2023
176
Stuart (ODay) Mariner 19 Yeopim Creek
Stabilize the mast sideways?
Ran into that issue on my ODay (Stuart) Mariner (19ft) with mast raising (25ft mast mounts on cabin top). The Mariner has swept upper and lower shrouds, and the mast is hinged to raise from the stern. Because the uppers and lowers are swept, there is nothing to keep the mast from swinging side to side as it comes out of the aft crutch. As the mast gets most of the way up, the shrouds tighten up, and the side-to-side swinging is no longer an issue.
With 2 people, the mast is manageable. One in the boat walking the mast up, and one winching. Or one to walk the mast up, and one to pin the forestay.
Single handed, a gin pole/winch arrangement is essential so that the mast can be raised slowly (or even stopped partway up) to allow checking for problems. To stop the side sway at the bottom of the lift, many different ideas have been tried, with one of the more common ones being legs that fit over the jib sheet blocks with the other end sliding up and down in the mast slot.
I went a different direction and implemented baby stays, using line with a LITTLE stretch. I added eyes about 6ft up on the mast to tie the baby stays to, and mounted a block on deck about 2" forward and 2" lower than the hinge point of the mast. Baby stays then run to the jib sheet cam cleats, although I have never had to adjust the baby stays during mast raising/lowering. With the baby stay deck point forward of the mast hinge, the baby stays also prevent the mast from sliding aft out of the tabernacle until the forestay is attached.
Work wonderfully. Tie the baby stays at the eyes on the mast, run them through the cabin top blocks back to the cam cleats. Pull them tight at the cam cleats. When I haven't used the baby stays, I've gotten in trouble with mast sway and twist, particularly when lowering. Before baby stays, more than once I dumped the mast over the stern quarter.
Fred W
Stuart Mariner #4133 Sweet P
Apr 15, 2025
3
Ya unfortunately there is no good spot to mount "baby stays" that are even remotely close to in line with the mast foot/tabernacle pivot. The original mast raising system i had was a similar setup to baby stays but I needed to have a way to keep tensioning the baby stays as the mast came up. This system shown in the vid works flawlessly solo and can be left "attached" while trailering the boat
Mar 6, 2008
1,391
Here is how I raise the mast on H25.5
Created a point at the base of the mast with dock lines as baby stays to keep the mast from swaying. I can lower and raise the mast by myself.
-na -NA Anywhere USA
Look at Hunter systems on the 23.5, 26, 240 and 260 as well as the Catalina Sport 22, 250. The key is centering either bow eye or slanted piece of ss plate to the middle of the masthead when lowering/raising the mast. Hunter used a ss cable with a turnbuckle fittings to adjust with. One end had a hook while the other had a quick release. With the struts on later models had a ss steel nut welded to the top of the tube. What was screw ss plate with a slight angle with a hole to run a bolt through the mast. It worted on the Hunter water ballast sailboats
