in manual
You should have received a manual but to answer your questin, you will see holes on both the stbd and prot side of the mast maybe 5-6 feet up. The T ball studs go there and the other ends to big u bolts on the side of the deck. Allow for play while the mast is down as they will tighten up.Crazy Dave Condon
