Jack Bristow
Here is a checklist we use to raise the mast on our H26. We seem to always forget something if we don"t use it.Mast Raising check list1. Untie front and rear of mast, unrap ties from mast2. untie all lines from cleats and stops3. move jib forward4. Attach forestay in mast fitting5. Check jib and furlaker halyards in front of spreaders6. Check main halyard behind spreaders7. Move mast back to step and attach wind vane and check shroud fittings8. Attach side support stays under all lines9. Put chin pole in mast10. Attach mainsheet tackle to chin pole and anchor eye11. Attach jib halyard to chin pole 12. Run mainsheet under all lines to port winch13. Tie furler to lifelines14. Raise mast to near vertical and check turnbuckles15. Raise mast to vertical16. Check furler orientation17. Insert forestay pin18. Remove mainsheet tackle19. Fasten mast wiring20. Put on boom, tie topping lift21. Put sail slides in mast track22. Fasten Main halyard23. Fasten vang24. Run jib sheets25. Route furling line26. Fasten mainsheet tackle27. Remove mast crutch28. Lower motorMast lowering check list to follow
