Re: Mast Pumping
Hi yes I have a frac rig 9/10 with swept back spreaders. I have a cap shroud, one lower shroud and one upper shroud going from the lower spreaders to the upper spreaders. I have an adjustable backstay. The fore stay has furling gear. The boat is a Bavaria 42. It is a Selden rig and I followed their directions and tightened the
cap shrouds, lower shrouds and then the upper shrouds. When sailing, the leeward shrouds are still tight. I do not believe the shrouds are to loose. I have seen other Bavarias and their shrouds are loose??
