It depends....
Kieth:Last year my rig was set with about 8" of prebend. More mast bend will help to flatten a sail that has too much fullness. Flatter sails are desirable in heavy air. In more moderate conditions, more draft might be desired. When racing, you might want to adjust your rig depending on the conditions. The standard 33.5 is not that easy to adjust on a daily basis; so, I would guess that most of us who race the boat try to find an acceptable compromise. Do you have a back stay adjuster? The rig is so easy to bend that I use a small unit on the split backstays. The unit was easy to install and not expensive. Good Luck, Ron
