I have a question about setting prebend on rigs (B&R and others) were you can’t bend the mast once you are underway. The three choices are straighter than, more bent than or follow the luff. If you bend it more than the curve of the luff, then when you raise the sail it will automatically be flattening it I suppose? By the same token if you set it straighter than the luff it will allow greater depth. If you go straighter will this make it difficult to move the draft all the way forward?
