Tony
I'm looking for guidance on proper tension settings for the shrouds. I've found that following the NorthSails guide (28 on uppers and 24 on lowers using a Loos model A guage) I get no pre-bend. The guide further advises to increase tension in the forward lowers to induce pre-bend. I tried this without much success. I was able to get 1/2" of pre-bend with the following settings - uppers 30, forward lowers 30, aft lowers 22. Since all tuning guides I have found recommend higher tension in the upper shrouds than the lower shrouds, how do I get pre-bend without the forward lower tension exceeding the upper shroud tension, and is this a good idea? I do have a split backstay adjuster. Am I supposed to measure pre-bend with the backstay adjuster fully tensioned?
