Mast pad eye
Mickey McLaughlin
I need to get a mast pad eye for a whisker pole on my H26. What kind should I get and aproximately how high up should I instaLL it? I have a 100% self-furling jib.
Steve
Experiment
Check Defender and West Marine advisors. I believe common sense will prevail once you set up the pole and see the geometery that makes sense with the least amount of restrictions and problems after experimenting with the full range of movement.
