mast
Rudy most likey can get you a mast ...he got me a mast for my 22 a few years ago. It is a Dwyer mast and you can order one from Dwyer mAst Co. as well. However, D&R got it for much less $$$ as they get them in bulk. Both Rudy and Dwyer hvae the specs for the mast on file so they will send you the proper length.When you buy the mast, you have the option of getting it rigged or unrigged. If you have the rigging from the old mast (and spreaders/spreader brackets, masthead, etc.) it is much cheaper to get a blank spar and do the drilling and rigging yourself ( it's NOT hard as this was my first boat and I had NO Idea what to do at first.) Measure twice, drill once. Rudy will give you all the dimensions.........Best of luck.
