Tony Bilello
I tried to remove my old antenna coax and had a new coax tied to it. When we pulled downward the old coax became jammed between what I assume is the anchor light wires. For fear of pulling anchor lite wires loose, i pulled back up to retrieve my new coax.My Question is....what could have the old coax been jammed on ? Is this coax run through some form of conduit inside the mast? If so, can i drill new holes on the other side of the mast and drop some wire and weight down and fish it thru?
