Mast luff channel replacement
Apr 5, 2005
2
-Catalina -27 and 30 Carlyle Lake
I need advice on how to repair or replace the poly channel that is in bad shape. Thanks
Oct 27, 2010
119
E-22 e-22 Stratford
LaVidaLoca:
The original mast from the 80's into the early 2000's did not have the plastic channel guards on them.
So one way to deal with it, is to remove the existing U.V. damaged poly bits and then make each side of the channel smooth.
Probably best done with the mast down..but in a chair you could at least carefully run your hand along each edge and deal with sharp bits..
bob pattison
Neil Pryde Sails.
