F
Franklin Post
I am buying a Hunter 33.5 (1989) and my survey showed that the mast lights were not working. In the survey, the boat was hauled and when it was out of the water, the lights on the mast came on. However, once we were back in the water and back at dock, the mast lights were not working. I have also learned that the current owner has said that the mast lights are not working. The surveyor told me I could probably pull up one of the floor boards between the V-berth and salon and I should find a terminal block. Then I should clean each terminal wire and that should do the trick. However, I am concerned that the terminal box is not under a floor board or that this will not fix the problem.Has anyone had this problem, and if so, what should I expect to have this fixed? (i.e. unstep the mast)F. Post
