Mast lightbulb replacement
W
wdeluna
I own a 1995 Hunter 29.5 and, like many boats that are slipped in the ocean, my mast light has stopped working. I suspect that the corrosion plays a big part in this, but, before I climb my mast, (and I only want to climb it once) does anyone know the replacement bulb for this particular model AND is there a LED replacement I can use instead?
thanks
Bill
joendj
Apr 4, 2007
17
Hunter 29.5 NY
Hi Bill,
I replaced mine with Led's. You need two (P/N 85645) for the mast light. They fit in very snug but they do go in. Clean the contacts while you are there and apply some type of conductive grease, if you want. It would help with corrosion.
I also replaced the three nav lights (P/N 74563) at the same time.
Here is where I got mine; both lights are listed on this page:
http://www.ledlight.com/festoon-hi-power-1-watt-led-light.aspx
Hope it helps,
Joe
1994 Hunter 29.5
