Mast light wiring under deck
7
Hunter 26 Kingston, ON
'94 Hunter 26. Wires from electrical panel to deck plug are now cut down flush with deck thru-hole and there's no slack in wire, so I can't attack them to the deck plug. Hunter said I could access the wire from near the cabin light, so I drilled a 3" hole and see a piece of rigid conduit running from starboard direction up to deck butt is sealed in a hard foam.
Has anyone had a similar issue?
