mast wiring connector
Hello, I have replaced my mast electrical connector as well. I used the five pin connector. I needed to pull the wire and connector out of the deck a bit to get at the screws on the connector itself. I started at the panel box, and pulled the wire leading to the connector, for some slack. The connector itself was embedded in alot of sealant, but after awhile it came out. Be careful when you are screwing the wires back onto the connector. I stripped out one screw and had to replace the new connector with another new one. But in all, it's not to bad to do.
